TPMS part #
Old Apr 4, 2007 | 06:31 PM
BrabusMan's Avatar
2009 VW CC
TPMS part #
Does anybody know -- or have access to looking up -- the TPMS (tire pressure monitoring system) sensors for a 2007 ML 350? I need the #s for the sensors and the valve stem, if available.
Thanks in advance!
Old Apr 4, 2007 | 07:07 PM
ShoremNJ's Avatar
ML 350-Black=Sold. New 08 C300 4Matic, Black/Black, P1, Ipod, Auto7speed, 10/10 hit 100,000 miles
It works off the rotation of the wheels, the stems are standard stems.
Old Apr 4, 2007 | 07:13 PM
SUNILP's Avatar
2015 E250D
sensor part no. 002-540-6617
stem standard 000-400-3213
AMG 19" and 20" stem 001-401-2713
Old Apr 4, 2007 | 07:38 PM
BrabusMan's Avatar
2009 VW CC
Thanks Sunman!
Shore -- FYI the 164 chassis takes physical sensors.
Old May 8, 2007 | 09:53 AM
Doctodd33's Avatar
ML350
where can i buy some tpms?....besides the dealership. I need spare tire pressure monitors for my s550.
thx
T
Old May 8, 2007 | 04:44 PM
SUNILP's Avatar
2015 E250D
try tirerack. They carry the older beru 315mhz sensors however the s550 uses siemens sensors.
Old May 8, 2007 | 09:11 PM
AdamG@NorCal's Avatar
EVOTECH Mercedes AMG
Or you can try Steve @ MBenzNL.
Old May 10, 2007 | 11:11 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Originally Posted by BrabusMan
Thanks Sunman!
BrabusMan --FYI, the '06 sure doesn't take individual wheel sensors.
Old May 10, 2007 | 11:36 PM
SEXYBEEST's Avatar
wife's car2014 ml350
it doesn't greg, what does it take?
Old May 11, 2007 | 12:02 AM
Run Flat Indicator system
Operates off the ABS sensors that compute wheel rotation and sound the alarm when any one wheel is consistently different than the rest.
Per my manual, p. 348, "While the vehicle is being driven, the Run Flat Indicator monitors the set tire inflation pressure by evalutaing each wheel's rotational speed. This allows the system to detect a significant loss of pressure in a tire. If a wheels rotaional speed changes due to falling inflation pressure, you will see a corresponding warning message in the Multifuntion Display. ..."
I'd be interested to see what the 2007 manuals say on this--anyone?
Old May 11, 2007 | 05:56 AM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
The Run Flat Indicator is for Canada Only in 2007. The Tire Pressure Monitoring System is for the US. Here are the pertinent pages from the 2007 Owner's Manual.
Old May 11, 2007 | 09:25 AM
RFI vs TPM
I wonder why they would make that distinction?
Old May 11, 2007 | 09:41 AM
BrabusMan's Avatar
2009 VW CC
Your correct GregW when I said 164 chassis I should have correctly stated that I meant all 07 and up vehicles.
The reason for the distinction between the two is because Canada only requires ABS style monitoring while in the US, all model years 2007 and up require, by Federal law, to have a physical TPMS sensor.
Old May 11, 2007 | 10:07 AM
DUTCH's Avatar
Canada also gets the Advanced Tire Pressure Monitoring System, which we do not get in the US. This Advanced System shows the actual tire pressures in the cluster display. See attached:
Old May 11, 2007 | 10:41 AM
BrabusMan's Avatar
2009 VW CC
Very cool! I was not aware of that. Wish that was an option (or standard!) in the US. I could see that being very helpful.
Old May 11, 2007 | 02:02 PM
btshep's Avatar
2020 GLE 580 | 2020 Ram 1500 Limited
can the advanced TPMS be implement and installed into a USA spec ml ? also how big of a job would it be
Old May 11, 2007 | 02:20 PM
Wolfgang's Avatar
MBs
Here's the supplier. Schrader Group was awarded with the contract starting with MY 2007 according to this press release on their site:
http://www.schraderelectronics.com/N...ge.aspx?news=1
@jerseytuffguy:
They seem to offer a retrofit kit according to the info on their site.
