wheel offset from gl to ml
GL and ML use different tire sizes.
The Mercedes wheel catalog does not indicate they consider them interchangeable.
you can use the stock bolts off your 19" rims. if you have 17 or 18" you need to get new bolts.
i'll be selling mine after the tires need replacing
btw, i should have clarified. the gl wheel offset still sit inside the fender area of the ml. it is only the size of the tires being 275 that make it stick out a very little.
if you were to do down to a 255 or 265 tire, i'm sure it would sit flush. also don't forget you need long bolts if you are going from 18 to 19
