MHI Bluetooth Interface Module with BB 8830
Old May 28, 2008 | 12:47 PM
MK330ci's Avatar
2002 BMW 330CI
I just purchased and installed the MHI Bluetooth Interface Module and it's working great with my BB 8830. Does anyone know if this module supports voice command dialing? I'm not sure what else this does besides using my phone hands-free.
Thanks.
Old May 28, 2008 | 01:15 PM
tarponbeach's Avatar
2021 GLC 300 4Matic
Thanks.
Voice command is a separate option. If you have two round "voice" buttons on your steering wheel, you have voice command.
Old May 28, 2008 | 01:16 PM
MK330ci's Avatar
2002 BMW 330CI
I do have the two round voice buttons on the steering wheel. How do I activate voice command to make calls?
Old May 28, 2008 | 01:36 PM
2021 GLC 300 4Matic
Go to the "phone" screen, and add voice tags, with telephone numbers for each entry that you want. The voice dial directory is separate from the phone book that your phone transfers via Bluetooth®. Voice tags will stay resident in the Command system, regardless of which phone is paired to the system at any given time. It actually works pretty well...not as good as Acura's system, but it is usable.
Old May 28, 2008 | 05:16 PM
MK330ci's Avatar
2002 BMW 330CI
Thanks!! I've give this a try when I get home. I can't wait to see this work. Besides making calls, could I use voice command for anything else?
Old May 28, 2008 | 08:00 PM
2021 GLC 300 4Matic
Yes you can. Switching between audio sources, and navigation commands.
