ML Recall
Old Aug 23, 2008 | 07:19 PM
paulybagadonuts's Avatar
2017 GLE 350 W4, 2016 C 300, 2012 E 350 W4 Lux, 2006 ML 350
ML Recall
Got a call from my Dealership today. They left a message saying I should come in for a recall fix but didn't say what it was.
I call back and of course there's no one there.
Any idea what it might be?
Anyone else hear of any recalls on the '06 ML?
Old Aug 23, 2008 | 08:30 PM
EX-BEEMER's Avatar
'08 SL550 Sport, '11 BMW 550ix M sport
Could be the trailer hitch recall. They had faulty welds on some trailer hitches. Mine was redone last week. They remove and completly re-do the hitch welds. Takes about 4-6 hours in the body shop.
Old Aug 24, 2008 | 12:27 AM
lkchris's Avatar
'10 CL550, '12 GL550
If it's truly a recall, you'll get a letter.
If you have gas engine, might be something about serpentine belt as hinted at GL forum.
Old Aug 24, 2008 | 07:16 AM
DUTCH's Avatar
2000 MB G500 NMLE, 2015 Audi Q7 3.0 TDI Prestige
There's a complete list of recalls and service bulletins here:
http://www.whnet.com/4x4/tsb_164.html
Old Aug 27, 2008 | 04:06 PM
Thanks Dutch
Finally got hold of MB today and they told me the V belt needs to get changed. I found it in the link you sent:
Aug 15, 2008
2008070002
Service campaign, Revision: Update to warranty information
Models 164, 164.8, 171, 203, 209, 211, 216, 219, 221, 230, and 251 with Engine 272 or 273
Model Years 2006-2007
Replace V-Belt Upper Guide Pulley
Guess it's back to the dealer for me. Not looking forward to going but what can I do??
Thanks again for the info.
Old Aug 31, 2008 | 12:20 AM
BruNo's Avatar
07' ML350
hmmm...could the squeaking noise i hear from the engine bay connected with this recall...
to those who had it done, please post here which pulley was replaced.
Old Sep 5, 2008 | 06:54 PM
benzoML350's Avatar
Mercedes Benz 06' ML350
Jun 04, 2008
T-B-42.10/80b
Revision: Work Procedure for Front Axle and Parts Information Updated
Model 164.122/175/177/186/822/871
Model 251.122/165/175/177
Model Year 2006 - 2007
Front / Rear Brakes Squeal When Braking
Such bs, awhile ago I went to my MB service advisor and complained to him about the squealing coming from the brakes. He brushed it off saying that it was just the humidity...I guess they really didnt care because I am leasing the car from them...
Old Jul 17, 2010 | 09:50 PM
Lance310's Avatar
2005 C240 4matic and 2007 ML320 CDI 4matic
If you plan to replace the belt yourself, it is easy. I have a 2007 ML320 and the procedure is the following:
1) Look at the ML owner's manual and it shows the belt path. Page 532.
2) Get a 17mm socket and put it on the automatic belt tensioner. Number 3 in sketch on page 532.
3) Use the 17mm socket to turn the automatic belt tensioner counter clockwise until the belt is loose.
4) Remove the belt.
5) Install the new belt according to the correct path until the belt is on the last pulley (you won't be able to get it around the pulley because the tensioner is at full position).
6) Use the 17mm socket to turn the automatic belt tensioner counter clockwise until the belt has enough slack to go around pulley.
7) Gently release the automatic belt tensioner.
8) Wash your hands.
The entire procedure will be approximately 15-20 minutes for your first time. 10 minutes next time.
I replaced my belt at 80k miles and it was worn with small visible cracks. I'll replace it next time around 70k miles.
Old Jul 19, 2010 | 12:35 PM
lkchris's Avatar
Recalls are for safety and emissions issues only.
Belt squeaks and TSBs are simply fixed under warranty.
Only recalls get you a letter.
Old Aug 5, 2010 | 11:42 PM
mattmancustoms's Avatar
mercedes
its not the belt that is replaced. the upper guide pulley is being replaced. they have changed the design on these drastically.
