Towing MPG with ML320 CDI
"This weekend I got 10.2 l/100km or 28 mpg imp. or 23mpg US:
Pulling a 2,500lb trailer through the mountains, then through surface streets cross-town. Average speed: 91km/h (56 mph)
Met another GL CDI owner in the same campground, and he was pulling a similar trailer, but he came down from Edmonton and only got 12.2 l/100km or 23 mpg imp. or 19 mpg US, but his average speed was 130 km/h or 81 mph.
Gotta love that!"
Average speed 37MPH
14.5 MPG
Ski Nautique and dual axle trailer weigh ~3000 pounds and probably a bit more aerodynamic than a box or camper trailer.
Without the trailer but with the bike racks I get about 20+ on the same trip up to the cabin and back. I start at about sea level and top out at about 6000 feet and the climbing starts during the last 45 miles. Typically I am seeing between 22.5 and 24.5 average on a tankful.
I was a bit surprised at the consumption, but it sure pulled strong no matter the grade or elevation. Oh well, still better MPG than the full size Bronco that used to pull the boat.
His problem is the bicycles on the roof.
I towed motorcycle trailer from Albuquerque to Corpus Christi and mileage started at 21 and ended at 19. Coming home, it increased as we gained altitude.
It's all about aero. Moreso than weight.
The benefit is that you get close to sea level power at 6000 feet, so one can effortlessly tow that trailer (and roof bicycles) to the top of the mountain. Altitude, weight and speed (RPM's and MPH) are your controllable primary factors. (Not in order).
But if you believe aerodynamics is the way to go, try folding in your outside mirrors.
The variable in the equation is aero drag and since it's less at altitude less work--and consequently less fuel--is required.
