Air Filter
Old Aug 31, 2008 | 11:11 PM
Sebastian3249's Avatar
2007 ML350
Question Air Filter
Anyone know the steps to replacing air filter(s) for ML350 (w164)? Thanks.
Old Sep 1, 2008 | 12:55 AM
lkchris's Avatar
'10 CL550, '12 GL550
Step 1: Buy the W164 Service DVD.
http://www.startekinfo.com/StarTek/o...stedDocId=9124
Old Sep 1, 2008 | 08:55 PM
moomber's Avatar
found it somewhere on the net. for ml500 but is basically the
same steps.
http://www.autohausaz.com/search/pro...2@Air%20Filter
File Type: pdf
Old Sep 5, 2008 | 10:31 PM
2007 ML350
Thanks!
Old Sep 15, 2009 | 01:50 PM
Fireleg's Avatar
2006 ML500
Thanks from me too
Old Sep 27, 2009 | 12:58 AM
am_beagle's Avatar
08 ML350; 07' Acura RDX; 05'FX45; 03'Murano
Originally Posted by lkchris
Be ware: the DVD disc does NOT work with 64 bit Vista computers.
Old Sep 27, 2009 | 12:02 PM
Benzo 003's Avatar
2008 ML350 4matic
I just replaced my filters with K& N filters...very easy and fit beautifully.
Very simple change....push the metal clip on the rear of the center of the engine cover back towards the firewall. It is way back in there...remove the front half of the cover that covers the oil filter housing(lift up and towards the front of the vehicle)...gentle pull back on each fresh air tube that goes to the engine cover until they come out...they can be pushed toward the center of the engine....then simple lift up on the box.
The box is held on by 4 spring loaded clips...dont be shy, it will lift off.
Once off, turn it over and loosten the 4 screws on each side to reveal the filters...
