Comand APS malfunction
Old Oct 7, 2008 | 03:41 AM
Droobui's Avatar
Mercedes Benz ML350
Exclamation Comand APS malfunction
Hello everybody,
I am reading this forum for quite sometimes, and I finally decided to register to share with you a little problem I did encounter this week.
I hope you can help me.
I bought a ML350 from the USA 6 months ago, imported it to Switzerland, and it was wonderful, I changed the odometer and the COMAND APS (which I found new on eBay). Mercedes Benz of Switzerland did the installation, everything was working just fine !
Since monday, my car doesn't have GPS signal anymore... I am unable to get a signal, I went to Mercedes Benz, but as I expected, they are trying to sell me ANOTHER Comand APS, which is the same euro model as I currently have... For 6'500$ !....
Anyway, did any of you encounter that kind of problems ?
What I found strange, is that it was perfectly working for 6 months, and then, suddenly, no signal...
I was in Holiday 1 week, and the car did stay in the garage without signal for 1 week, could that be it ?
Thank you so much guys for your heads up.
I am quite a "beginer" in everything technical...
Have a nice day !
Best Regards
Jonathan
Old Oct 7, 2008 | 11:08 AM
rob13572468's Avatar
PREMIUM SPONSOR
ML350, Lotus Elise
Originally Posted by Droobui
Hello everybody,
Have a nice day !
Best Regards
Jonathan
Hello jonathan,
The loss of gps signal could be a few things: it could be a bad antenna, it could be an issue with the teleaid module (which shares the GPS antenna with the nav) or it could be the aforementioned command that is the problem.
When you went to the dealer did they do a diagnostic test on the systems and do you have the results of the test? what we want to find out is whether or not the teleaid system was getting a gps signal and they can test for this...
Old Oct 7, 2008 | 02:28 PM
Droobui's Avatar
Mercedes Benz ML350
Originally Posted by rob13572468
Hello jonathan,
Hello Rob,
Thank you very much for your informations.
When I first gave the car to Mercedes Benz, they did the installation, and everything was runing just fine. I do not know if they did a "diagnostic test" and I do not have the result.
What are you suggesting ? That I try to replace the "antenna" ?
That they try to change the Comand APS to see if that works ?
If I can, I would love to avoid the replacement of the Comand APS, almost 7'000$ I mean....
Anyway, thank you for the informations, I will take the car to Mercedes soon, and I will let you know.
Any other informations are welcome !
Thank you guys for your support !
Old Oct 9, 2008 | 09:43 AM
PREMIUM SPONSOR
ML350, Lotus Elise
The service department can plug your vehicle in make a better determination of where the problem is exactly. Specifically they need to test both the command and teleaid systems to see if either system is reporting a GPS fault. (they share the same GPS antenna). So if both report a fault then it is likely that the problem is the GPS antenna or (to a lesser extent) the GPS splitter. If only one unit reports a flaw then it is either a problem with the unit or a wiring problem.
The quickest way to test is to get a hold of a GPS antenna with a blue FAKRA or SMB end and plug it directly into the command GPS input. then see if gps fix is restored (remember the unit can take up to 10 minutes to register position).
It is almost *never* the command itself that is the problem when it comes to gps issues unless there has been damage (e.g. water in the unit or something like that). it is usually the GPS antenna that goes bad due to corrosion or a wire is pinched and eventually failed.
Old Oct 10, 2008 | 02:34 PM
mortenmol's Avatar
07 GL420cdi, 07 ML63, 07 CL500 and more
no teleaid in euro-comand
Old Oct 11, 2008 | 05:07 AM
PREMIUM SPONSOR
ML350, Lotus Elise
correct... but were talking about a US spec ML... which does have teleaid.
