Question regarding after market subwoofer
Old Mar 7, 2009 | 03:00 PM
xbondq65's Avatar
2012 C63 AMG
Hi,
I have a 2008 ml350 and was wondering if anyone knew if it was possible to install an after market subwoofer. If so, how do you do it? I know that this audio system is difficult so that is why I am asking. Thank you very much
Old Mar 7, 2009 | 08:33 PM
360º's Avatar
2008 ML550
yeah its doable...... should look at getting a JL Clean Sweep.
Old Mar 8, 2009 | 03:36 PM
xbondq65's Avatar
2012 C63 AMG
Thanks for the response. If I purchase this device how do I connect it to the head unit? Does it require a lot of re-routing wires and such or is just a plug and play type of thing? If so, do you know which wires to use? Thank you very much
Old Mar 8, 2009 | 03:43 PM
360º's Avatar
2008 ML550
not to hard but professional install would be best....
you'd need to splice wires going to the speakers.
then run it through the clean sweep (clean sweep takes all high level noise out and leaves only low level base)
then you'd go to your amp and then to the sub.
http://mobile.jlaudio.com/products_c...php?page_id=94
