ML350 (W164) Service Access
Old Mar 26, 2009 | 11:27 AM
jrosmus's Avatar
2006 ML350
In order to access the service menu on the new W164 you need to do the following:
1) Put key in 'on' or '1' position
2) Toggle the MFD to the mileage/temperature setting
3) Push the "R" button in the dash three times
Now you can toggle around the menu, find out what services are due and reset if necessary.
Thought this might be helpful.
Jens
Old Apr 21, 2009 | 09:52 PM
dc2774's Avatar
Comand Diagnostics Menus
I was playing around with Comand and read through some of the other posts, i tried the OK+7+Mute to get into the additional Comand menus. I tried the codes in both MAP mode and in SERV mode and each gave a variety of menus. Has anyone tried altering any of the values?
I was able to play with brightness of the screen; EQ settings (FLAT or Preset) and a few other things. I didn't want to mess with too many of the buttons not knowing what I'm getting into Are there any other features that we can turn on in this mode?
In addition, I pulled some SW/HW versions of the diagnostic menus - these seem fairly old - is an update in order? If so, I would like to make sure the SA can get me the right ones.
SW: KW18/05 v1.000
HW: KW10/05
DC Model: 1648200779
Boot Version: M07/S07
Software Code: 01.70.00
Thanks in advance,
Old May 10, 2009 | 11:21 PM
Markizzy's Avatar
C230
off topic but how do u reset the digital clock?tried searching the manual but i didnt find it.
