How to wire trailer lights??
Old May 25, 2009 | 08:28 AM
viperjesse's Avatar
2007 ml350
Hi guys, I'm a new ML350. Burgandy and tan 07. I absolutely love this vehicle.
I added a trailer hitch from etrailer. Now I have to wire the lights. I've read thru many posts here and realize it's not as simple as it may seem.
Could anyone give me instructions on how to wire the lights and what I would need to do the job??
Thanks in advance
JZ
Old May 27, 2009 | 11:50 PM
MB Dave's Avatar
Suzuki Burgman Executive
Thanks in advance
JZ
take it to uhaul...
Old May 29, 2009 | 11:29 PM
lkchris's Avatar
'10 CL550, '12 GL550
Be sure you specify that the "boys" down to UHaul don't cut any wires or use any scotchloks.
Old May 31, 2009 | 09:59 PM
GregW / Oregon's Avatar
2020 GLE 450; 2023 BMW M2 Coupe
Trailer wiring
Haven't tried these, but may be applicable to your situation:
http://www.hidden-hitch.com/results....nz&model=ML350
Be aware LED trailer lgihts may trigger an error code without a special cable.
http://www.etrailer.com/pc-~V39010.h...utm_medium=ppc
Old Jun 2, 2009 | 03:28 PM
viperjesse's Avatar
2007 ml350
Thanks guys, don't think I'd get Uhaul. This is my baby, if I gotta pay it'll go back the the dealership.
Thanks again
JZ
Old Jun 2, 2009 | 08:12 PM
Vernl's Avatar
ML320CDI 2008 all options inc air suspension
If you are willing to have it done at the dealer..you should have just had them install the hitch, wiring, and Sam module, then things like the tow haul mode etc will all work as they should and you would have the full 7500lb capacity as well
Old Jun 21, 2009 | 10:25 AM
EmptyCoolerz's Avatar
ML 500
Any update on this issue? I just installed an aftermarket Draw Tite on a 06 ML 500, and for the life of me can not find the pre-wired trailer light wiring. UTFSE and Google have not yielded anything either! Thanks.
Old Jul 14, 2009 | 10:49 PM
brakel8's Avatar
ML500 AMG pkg
If you did not order the vehicle with the hitch option then there are no wires. The rear SAM needs to be replaced and coded for the option and the harness then installed and connected to the rear SAM.
Old Oct 27, 2009 | 02:27 PM
viperjesse's Avatar
2007 ml350
It looks like the trailer wiring as of 2007 are DEALER ONLY applications.
I called the dealer and they would have to order and install the hitch and wires as a package. Didn't ask the cost. Does anyone know what it might cost?
Guess I wasted my time and money installing an aftermarket hitch.
Old Nov 14, 2009 | 05:26 PM
realralfy's Avatar
2009 ML320 Bluetec
The hitch kit (only way to get the wiring parts, doesn't include the SAM.) is $850 and they want 5 hours to install. Sometime during the 2009 model year they started including the SAM, more pain if you gatta buy it....
This is rape by dealer...
$850 (hitch kit)
$600 labor (5 hours @ $120/hr)
$500 SAM (This is from memory but close)
$1950 = Rape by dealer
