Inadvertant owner
We were looking for a replacement SUV. The lass got all fired up about the value for money this vehicle represents.......sigh. Some wall st journal article, anyway she was watching an auction with no reserve and I thought to be nice since it appeared to be low that she could put a bid in $100 higher in the last 5-6 minutes. Bugger me -- WE WON
. so we now have a '06 with 27k miles on it.QUESTION:
Are there any sites you recommend for accessories - like floor mats?
QUESTION:
Can this forum supply suitable info on potential issues and preventative maintenance? I'm a member on bimmerforums for my 850 and its a great source of help -- I assume this is similar?
Cheers
Hip.
There have been a zillion posts about various aspects of maintenance. Use the Search function as necessary. There have been almost as many posts about issues; do the same thing. If you change your own oil, you'll need an extractor pump that uses the dipstick tube, otherwise it is straighforward. Use only Mercedes approved oils. Brakes are simple and straighforward. Transmission flush and change is essential every 40,000 miles or so but is not an easy DIY. As with most modern vehicles, "maintenance" mostly means checking things.
Good luck with the ML!
Thanks for the quick response. I will head off and search for what I need.
I'm glad to hear there are no major drawbacks with the vehicle in general.
The mats tip is MUCH appreciated.
Hip.
Now, if you find this issue, I URGE you to run to the dealer ASAP and get a free fix
Keep us posted and enjoy the ML
