Should I buy this 08 ML320 CDI?
http://www.autotrader.com/fyc/vdp.js...type=b&make=MB
One owner who traded it in just under 2 years. All seems good but it has had a few items repaired. I will list them as best I can below.
Would you buy this rig or keep looking?
This seems like a lot?
2/09 Glow plug relay replaced
5/09 Steering coupler and steering shaft replaced
9/09 Brake pressure? sensor replaced
1/10 Oil level sensor replaced
3/10 Driver xenon assembly replaced do to bad power source
3/10 Front differential breather hose plugged (cleaned out)
one recall done.
Service A ans B done on time.
Fuel filter has not been replaced.
one recall done.
one recall done.
one recall done.
Was the Steering coupler/shaft a recall? The other things are minor. Ask them to change out the fuel filter and make sure the correct oil has been used.
