2010 ML350 Blutooth & Rear A/C Question
Old Apr 3, 2010 | 07:33 PM
uscjgood's Avatar
2010 ML350 RWD
Hey all -
New here - just bought my first benz a few days ago (came over from the bmw world). In any case, when I do bluetooth w/ my iphone in the car, the contacts show up as last name, first name - is there anyway to change that?
Also, as far as the rear a/c is concerned. It doesn't seem to blow at all. I've tried pretty much everything, but i'm a newb so maybe i'm just an idiot.
Any suggestions?
Thanks,
Jordan
Old Apr 3, 2010 | 07:57 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Yes I believe you can change the address book but I think you must do it with the I Phone. Re load your I Phone and as I recall it gives you the option of how it will read out. Then reload your Command after deleting the original address book. As for the rear a/c, are you certain the "rear off" is not engaged?? Its one of the buttons that are in the rt side knob
Old Apr 3, 2010 | 09:45 PM
uscjgood's Avatar
2010 ML350 RWD
A/C fixed itself (you may have been correct w/ the rear off function. Iphone still last/first - can't figure it out. Tried just about everything - thoughts?
Old Apr 4, 2010 | 10:06 AM
sosh's Avatar
I too had the I Phone issue and corrected it. At this point for the life of me I can't remember how I did it. As I said I think I recall doing something with the I phone but am not certain. Keep trying perhaps you will stumble on to something or maybe someone else will jump in here.
Old Apr 4, 2010 | 02:09 PM
pharaoh's Avatar
2010 ML550, 2012 GLK350 4Matic
Do this in your iPhone, in case you haven't done it yet.
Goto Settings->Mail,Contacts,Calendars-> Scroll down to contacts and select the sort order and display order to First,Last.
Old Apr 4, 2010 | 04:19 PM
sosh's Avatar
That sounds like what I did. Then you must delete the addrss book in the car and reload from the I Phone.
Old Apr 6, 2010 | 10:54 PM
uscjgood's Avatar
2010 ML350 RWD
That was one of the first things I tried. Didn't work. Any other ideas?
Old Apr 6, 2010 | 11:10 PM
sosh's Avatar
Sorry no other ideas, that should have worked. When you did it did the book in your phone come up as it had been or reversed?? It should have reversed itself. Perhaps you should try clearing it out and then starting from scratch and reloading it with the "reversed" settings then downloading to the command after clearing it out.
Old Apr 6, 2010 | 11:36 PM
uscjgood's Avatar
2010 ML350 RWD
I originally had it as first, last on both (on my iphone). when i uploaded to the car, it still came in as last, first. I then tried to delete and start from scratch but to no avail.
Old Apr 7, 2010 | 12:23 AM
ajSvat's Avatar
ML63, VW Jetta, STI, Ducati Monster 1100
Interesting, post as I have both iphone and a HTC diamond. The contact list on the iphone itself displays alphabetically by first name. The HTC Diamond is set to display contacts by last name. Now when paired up to the Bluetooth they get displayed on the command screen opposite from the devices.
I don’t have a solution to your post but someone might come up with the added information.
Old Jun 12, 2011 | 12:10 AM
doubleMBowner's Avatar
2011 ML350 & E350
Hey... long time MB owner, first time poster.
I'm having the exact same issue with my iPhone (iOS 4.3). I've always had my phone set to First Name, Last Name and my 2011 ML is reversing it to Last Name, First Name.
This kinda makes the voice command useless when I just want to call Bob.
I know it's been a few months and wondering if anyone has figured this out yet?
