2009 ML350 Navigation
Old May 24, 2010 | 02:21 PM
Navigura's Avatar
GL450
Anyone knows is the 09 ML350 Navigation system is Hard Drive or DVD based?
If DVD based, where is the DVD located at? The screen doesn't have the Eject button as older versions.
Thanks!!
Old May 24, 2010 | 03:51 PM
bruntoj's Avatar
2010 ML550 (W164)
HD
2009 (and 2010) US spec. systems are hard drive based and updated via DVD using the CD/DVD slot on the front of the unit. Not sure I fully understand your comment about there being no eject button - there is one next to the slot. The screen is fixed and doesn't "eject" out of the way to reveal a single disc slot slot like prior years.
Old May 24, 2010 | 04:12 PM
Navigura's Avatar
GL450
Thanks bruntoj. Yeah I was referring to the eject button in the screen as in the prior years.
So are the Navigation Disks on the Hard Drive based system interchangeable with DVD based systems? In other words, can I use the DVD used to update the hard drive files in an older (DVD-based) navigation system?
Old May 24, 2010 | 08:54 PM
bruntoj's Avatar
2010 ML550 (W164)
No idea, but suspect you might find the answer here:
http://www.mercupgrades.com/
Unless I'm mistaken, the 2009/10 US spec Command is called NTG2.5.
