Bearing and Transmission
Thanks.
My 08 is recommended at 39k and no more after that.
I just recently "puked" a front right wheel bearing after a long trip and the only thing that made it stand out is that it made a "wirrrring" noise at 40 MPH and up. No vibration and grinding noises.
I would investigate the tire wear in regards to the vibration. Worn tires that have not been balanced in a while or a vehicle out of alignment with older tires can certainly cause odd vibrations.
I would consult the parts dept at a M/B dealership in reference to front and rear bearings being interchangeable. I was quoted 800.00 for 1 bearing if it was out of warranty. Not a cheap repair to gamble with.
