Your city lights use my 194 Wedge LEDs. Your interior map lights also use my 194 Wedge LEDs. Your interior step lights use festoon LEDs from my spec sheet, but I don't know what length festoons. If you can pull it out and measure it tip to tip, I can see what I can do, but I carry 31mm, 36mm, 38mm, 39mm, and 41mm so should have you covered.
AZN Optics be closed Thanksgiving Week (Nov 20th-24th). We will still process electronic orders, but shipping of order will be delayed till Monday Nov 26th.
Formally announcing that all our V3 units have not been adapted with Gel Packs. This is a high temp resistant gel substrate that we've applied to the resistor and critical solder joint to both help encapsulate the heat and insulate against heat soak, making these units more durable against heat and electrical surge related incidents.
bump. We'll be introducing a new line of H7 and H11 plasma LEDs in the next few weeks. These would be ideal for fog lights if you don't want to upgrade to HIDs. Package will be put together with big Morimoto load resistors.
Id like rear license plate lights, parking lights, conveniance lights on the side mirrors, fog lights and if you have a complete interior lighting too.
yeah, the rear plate specs on the new ML is just different from all the other MB models, including other parts on the same ML. Don't ask me why MB did that.
Do you have any confirmed interior package for the 09-11 models that shut off after you close the door like the stock halogen bulbs do? And not just dim down and stay on.
I haven't found a set that wont turn off once the door are shut and the car is running.
Although we haven't personally tested on a 164 interior, we have on other Mercedes lineups. They shut down to full off when they are supposed to in those applications. Footwells will dim though but that's by Mercedes design as those are ambient lights and power is being provided to function as such.
I did try all LED from everywhere included AZN for my 2011 LED package, but had no luck! they all show error message.
I used AZN led on my car (2008 ML 320) and it worked perfectly. I think you have to take specific model of bulb (LED) and you should be OK...If you check my post in past, you can find what type of LED, I used.
