2007 ML 350 Command Operator's Manual
Subscribe
Jan 16, 2011 | 03:05 PM
Does anyone know where I can get a pdf version of the Command Operator's Manual for my 2007 ML350 4Matic? It has the P2 Package (Nav, Rear view Camers, etc). I bought it as a CPO in April of 2010. When I went to change the clock for the change to Standard Time, the ML350 Operator's Manual stated that I had to reference the Command Operator's Manual. I figured I would search Owner's OnLine and download it, but couldn'y find it.
Reply 0
Jan 16, 2011 | 05:06 PM
I actually have that same model year.. not seen a pdf.. but i can tell you setting the clock is easy once you figure it out.. its not intuitive; you have to navigate to that screen setting, then actually push the joystick in like you are pressing it to click on and off daylight savings time to get it to 'stick'. hope that helps
Reply 0
Jan 16, 2011 | 07:53 PM
2007 ML350 Command Operator's manual
I was able to change from daylight savings time to standard time, but how do you actually change the time. Also how do you change it from 12 hour formant (AM or PM) to 24 hour format (Military Time)?
Reply 0
Subscribe
Currently Active Users (1)
