how can i drain the fuel from my fuel tank? there is no drain plug.
Quote:
Flip your car upside down!Originally Posted by BruNo
i need a smarter idea
No, just use a pump
pump? as in pump it our thru the filler cap? the ML has 2 tanks, one on each side
Disconnecting the fuel line should work if you can find it, but don't forget to open the filler cap. What happened? Filled a diesel with gasoline or vice versa?
