Activating DRL and KM's - Help
Hi all
I'm exporting an 2008 ML550 to Canada and I called a Washington MB dealer to see what he would charge for activating the DRL and switching to KM's/Hr on the speedo.
The SA stated that the changes can be done through the steering wheel. Is this correct? I thought it needed to be plugged in and reprogrammed..
Cheers and thanks in advance.
I don't believe you can turn on DRLs yourself.
You can use the steering wheel controls to show digital speed in km/h but I believe you can only change the analog speedometer that way if you have a Canadian model ML. Legally you don't need to change it if the markings are also shown in km/h.
