ML 320 CDI
Old May 6, 2011 | 04:28 PM
MBZ_lover's Avatar
06 E320 CDI
ML 320 CDI
I am starting to investigate a ML 320 CDI to buy for the wife, I have an 06 E320 CDI and love the engine on all levels.
My big questions for those that own one:
- Where are they made, Germany or US ?
I really don't feel good about US made cars, can you tell me your thoughts.
- Is the ML a reliable vehicle?
- Is the ML a smooth ride?
Old May 6, 2011 | 11:52 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
All of them from day one are Made in the USA!!!
What's wrong with US made cars? I have owned several domestics. They have been great.
My ML has been just fine. As with all automakers, there are glitches common to them, but warranty and manufacturing improvements have fixed these so far. Try searching around the forums to see common complaints.
Obviously my best "like" is the 31MPG that it will give on the highway. Also the power, smoothness and engineering. (Features, design and construction.)
All I can say is good luck trying to find one. With the price of fuel, most people would probably opt to keep theirs.
Old May 8, 2011 | 02:29 PM
Stesl's Avatar
04 sl 500, 07 ml 320 cdi
quote dgiturbo
reliabe 100% (the engine)
smooth ride, yes a lot, even too much when you want to go fast,,,
Old May 9, 2011 | 12:22 PM
lkchris's Avatar
'10 CL550, '12 GL550
Drivetrain is made in Germany.
Final assembly is in Alabama.
Old May 9, 2011 | 01:27 PM
Stesl's Avatar
quote +1
Old May 12, 2011 | 09:15 PM
MBZ_lover's Avatar
06 E320 CDI
Thanks for the information guys, it sounds like those that have them, love em?
I have a 2006 E320 CDI that is amazing and really enjoy it, fuel economy included...
Anything else you can provide on what to get in the ML CDI, what to look for, etc. would be helpful.
Thanks in advance.
Old May 13, 2011 | 01:20 PM
dgiturbo's Avatar
Personally, I use the Airmatic suspension during winter to gain clearance on unplowed snow roads.
Sat radio is used daily, and Nav is a real plus, even though I have not updated since new. Also, no matter how cold it is, in 4 minutes there is full heat. Steering wheel and seat heat is also nice touch. If you get one with the trailer hitch, make sure the recall was done.
If I had to complain, my biggest issue would be the fact that my headlamp washers freeze up and do not spray in winter, and I have to mix a special brew enhanced with rubbing alcohol to minimize this. Also Parktronic and snow does not play well with each other.
As you can see, my issues are mostly with winter use, and the newer ones (09+?) have heated washers and so on.
I have seen some of these advertised with leather, when it actually has MB Tex. Easy way to tell is to look at the wood trim. If it is really dark wood, then it's leather. Light wood = MB Tex. Also factory Xenon light always have headlight washers.
Remember to check that it is 4Matic. (Look for CV axles in the front wheels.) There was a small percentage that was made rear wheal drive only.
Good luck with the hunt.
Old May 19, 2011 | 12:53 AM
vegeta's Avatar
06 SLK55, 22 EQS450
I also have an 06 E320 CDI and then bought an 08 ML320 CDI. The ML has been a great vehicle. The ride is not as smooth as an E, but not bad by any means. I have about 27,000 miles on it. We drove it from Louisiana to Toronto via Nashville & Philadelphia and it was quite comfortable. I haven't seen 31 mpg but I have seen about 27-28mpg. Hope this helps....good luck with your decision.
Old May 19, 2011 | 01:34 AM
MB Dave's Avatar
Suzuki Burgman Executive
Cars are made by robot's almost no people involved. Theres nothing to worry about.
Old May 19, 2011 | 10:43 AM
06e320cdi's Avatar
2008 ML320CDI
I am in process of doing same thing. I have 06 E320 CDI, I have someone interested in purchasing it. I have been looking for a super clean 08 ML CDI in my preferred color combos. Hope to do this while 1.99% is being offered
