is it safe to wash engine bay??
In order to prevent any residual water I missed from causing any potential problems, I took it for 10 mile spin at 55 mph.
From the owner's manual:
"Prior to cleaning the engine compartment make sure to protect electrical components and connectors from the intrusion of water and cleaning agents. Corrosion protection, such as MB Anticorrosion Wax, should be applied to the engine compartment after every engine cleaning. Before applying, all control linkage bushings and joints should be lubricated. The poly-V-belt and all pulleys should be protected from any wax."
Hmm do you have a different manual?? I actually reda through my manual and there was nothing in the engine section and the care and maintenance section.
A cloth dampened with a strong grease cutter will do the job far better and safer than spraying water around the compartment.
