catalyst sensor need replacement ? ML350
Old Aug 25, 2011 | 01:26 PM
blue960's Avatar
W210 - V6'02 / W163 - V6'02
Unhappy catalyst sensor need replacement ? ML350
hi guys, my ML350 is at MB dealer for engine & transmission oil change, and i just been informed that all of the catalyst sensor need to be replaced as it's shown as not working properly when they check using stardiagnost...this can result to high fuel consumption.
they said there are 2 (left and right) catalyst sensor at the front engine bay, and another 2 after the manifold.... and the cost is almost $2k .....
need some advice whether those catalyst sensor is really that pricey, or i can get them from ebay or somewhere (new) ?
thanks
Old Aug 27, 2011 | 08:15 AM
Vernl's Avatar
ML320CDI 2008 all options inc air suspension
Do u mean O2 sensors?, if so, they are available online for about 100 bucks each and take 10 mins each to install.
Old Sep 10, 2011 | 10:36 PM
blue960's Avatar
im not sure if that is O2 sensor, dealer gave me this part number 0035427018 .... does anyone have a clue what part this is and where i can get it (not from mb dealer....) ?
Old Sep 11, 2011 | 12:07 PM
B-tsai's Avatar
CLK320, ML550, SL55, GL450
Mymercedesparts.com has your part number for $200 each. It says that its the pre-converter sensors.
and I think Bosch #17016 on amazon.com are $106 each and are for the front of the car... (its the oem one too per autohausaz.com)
So I think they are the one and the same...
I'd say get the two from Amazon and head to the nearest muffler shop for install.
The rear post-cat sensors.. double check what the model number is.. from the diagrams I see on mymercedesparts... they left is different from the right (and the right is cheaper at $98 vs $152 for the left.).
Old Sep 13, 2011 | 01:05 AM
blue960's Avatar
@b-tsai ... thanks for the referrence.
searched the amazon and found 'power pro' brand ... i thought it should be OEM by bosch, right? is it safe to take 'power pro' brand?
btw, my ML350 is RHD, would the cable setting be different with LHD or as long as it has the same part numbers, then it's ok?
i was also informed the starting motor is already weak .. at 31k miles ... trying to search part# 0061510501 and turns out the price is $500 ... woow ... pricey...
Old Sep 13, 2011 | 04:19 AM
B-tsai's Avatar
Best to use www.autohausaz.com and www.mymercedesparts.com to reference your part numbers to be certain.
