How to turn off TPMS ?
Old Sep 17, 2011 | 07:29 AM
blue960's Avatar
W210 - V6'02 / W163 - V6'02
[/IMG]hi, just put up carlsson 19" wheels on my ML350... everything went well except ..there is a message come up on MID "please check tyre pressure......"
how can i turn off this feature? my carlsson wheel doesnt have tpms..
thanks
here is how it looks like after 19'..
Old Sep 17, 2011 | 02:32 PM
komp55's Avatar
ML550
Why didn't you transfer the TPMS sensors to the new rims?
Old Sep 17, 2011 | 02:45 PM
blue960's Avatar
oops .. you mean we can move the sensor? where can i find the sensor on the standard rims? is it on all the 4 rims?
Old Sep 17, 2011 | 04:09 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Valve stems
Old Sep 17, 2011 | 11:35 PM
eeferber's Avatar
'11 ML350
yes, 1 sensor per wheel.
Old Sep 18, 2011 | 09:22 AM
blue960's Avatar
Sorry .. Im a bit confuse...
Already Removing 1 of the tire from original wheel at tyre service but could not find any sensor on the inside part of wheel (this part is covered by tire when the tire is installed).
Checking on the valve stem, it is just regular valve stem. Can I get a picture what to look on the original wheel, pls. How is the TPMS valve stem different compared to on TPMS?
Old Sep 18, 2011 | 09:37 AM
sosh's Avatar
You dont say what year ML. There are 2 types of the tire pressure system. One reads the individual pressure of each tire and that has the sensors in each valve stem. The other uses the vehicle sensors to measure the rotation of each tire and if a tire is low will give the warning you see but does not show each tire pressure. If yours in the latter it just needs to be reset after you check each tire for the correct pressure. This system also will not tell you which tire is low. Read your manual and reset the system per the instructions in the manual.
Old Sep 18, 2011 | 10:02 AM
blue960's Avatar
Oops forgot that .. It is 2007 ML350.
I think mine has the 2nd version tpms coz it doesn't give the tire pressure of each tire. I did reset it and last night was still blinking as a flat tire warning.....aarrggh....
Changing from Original 17" to carlsson 19" and using tire size as per advise on manual book increases about 1" on overall diameter, this shouldnt be the caused, right?
Old Sep 18, 2011 | 10:21 AM
sosh's Avatar
You certain you reset it correctly? I recall from the 06 ML500 I had that it was a bit tricky to reset. However its possible that the increased diameter could have some effect but I am not sure as many guys have done what you have and I have seen not many problems like you have. Suggest going into a dealer and asking them to reset the system. Should only take a minute of their time.
Old Sep 19, 2011 | 04:54 AM
blue960's Avatar
done ... went to dealer and asked their assistance to reset it ...voila no more faulty message.
thank you guys.
