New wheels for my 06 ML, Questions
FRONT WHEEL SIZE/OFFSET: 20X9.5 AND OFFSET IS 46MM
REAR WHEEL SIZE/OFFSET: 20X9.5 AND OFFSET IS 46MM
BOLT PATTERN: 5X112.
FINISH: BLACK/MACHINED FACE.
It's a jump and I have a couple of questions.
1. How much more will the ride suffer? My brother has a 2008 ML and it seems that he has a softer ride even though he has 19" wheels on his. I wonder if the suspension changed or was adjusted between 2006 and '08?
2. With this upgrade, how is the speedometer/odometer affected?
3. I have no idea what the 46mm offset looks like. Do you think it will look normal?
Here is the ebay listing that I've been eyeing: http://cgi.ebay.com/ebaymotors/20-ME...1#ht_500wt_956
Thanks for help in advance, I really really appreciate it!
I personally decided against the 20" rims. I'm happy with my AMG 19" wheels, as I think that the ride quality is a lot more important than just the looks... and the 19" rims seem to be a good compromise IMO.
I do not have an Airmatic suspension and neither does my brother. I would do the 19" as he has but the wheels I like are only offered in the 20" size.
The wheels come with or without tires. The tire size is 275/45/20. I don't know much about wheels/tires, so is that close to the 295/40/20 and which combo do you think will look better? (I'm sure I could probably get a different size tire put on if I asked)
Thanks so much again!
Well... uhmmm, to cut it short: It's really hard to give an advice here as this has a lot to do with personal preference. The best thing would be if you have the chance to go for a test ride with the desired wheels, before you buy.
F 255/50/19 9.5; R 285/45/19 11. I'm working on the springs and replacing it with lowering springs.
