Well my mirrors were taken of a crashed ML and they cut the plugs :-s to take them off... Smart guys :-s
I will try changing the motors inside, the rest won't be extremely hard. A wiring diagram for 2010 mirrors or a high quality picture like your FDC_008 would really help. Or a picture of the plugs with the coloured wires on top would also be great
But I think that 13 is not my lucky day
Can you ask them to take the door panel off and give you the plug.
I don't know if you can buy the plug separate are you using the existing plug of the vehicle? Perhaps you can go to M B Parts dpt. and see if they have the mirror in stock and tell them the situation and maybe theyll let you see it and then you can see the wire colors and the clip.
It was a really hard job
But I made it. I took the motors from the old mirrors, and made a custom wiring from the old wiring, that fits and works perfectly with the new mirrors. Of course everything made in a professional way
Everything works except the "blind spot" which is not installed on my car. The only problem that I am facing now is to change, somehow, the yelow bulb form the number plate to a led light as it is the only yellowish light on the exterior of the car. The problem is that I tried 10 different types of can bus leds and none worked (check lamp error). I saw a tread about the cars with production date over 03.2009 have a different check method and they detect any light malfunction different than the previous to 03.2009.... My car is 09.2009, so that's a new challenge.
^^That looks awesome! Nice job.
Quote:
I asked them for the wirings, but the car was sold allready. I first bought the mirrors and took them for a paint job. After that I waited a bit so the weather gets a little hotter so I won't freeze outside Originally Posted by swefoto
And 4 weeks passed till I discovered that I need the original wirings too
But it was a happy end situation in my case with a little brainstorming
Quote:
Cure for small vantage point. The 06 side mirrors were always to small for a truck/SUV because they were originally designed for the sedans.
For my 06 ML I purchased the new 2011 164 mirror assembly.
It consisted of the;
mirror motor, with memory and auto dim PN 164 810 46 93 -7 (R)Pssgr. 164 810 51 93-7 (L)Driverside
mirror cover, 166 810 02 64 7 (R) 166 810 01 64-7 (L)
cover molding, 251 810 02 15 -7 (R) 251 810 01 15-7 (L)
and the mirror Glass. 166 810 14 19 (R) 166 810 13-19 (L)
In the case of color coding the motor, housing and molding can be color ordered. Simply substitute your color code instead of the -7. example. my color code is 5349 (Alpine Rain) so its 166 810 02 64 5349 and so on.
The original equipment included memory seats which included mem mirrors as well. They feature;
Mem. position adj. (by key chip)
remote fold away,
reverse tilt assist,
lock and fold away
auto dim,
defrost heated,
under side courtesy light,
and of course the amber turn signal.
The unit I purchased has all those features (plus N/A blind spot warning)
First I removed the tweeter speaker cover with a 1 inch spatular and then removed the speaker from the housing. Next I removed the door panel;
push the lock/unlock buttons at the same time and pull the small pin out to remove .
Remove the hidden carriage bolt inside. (4.5 mm Hex fitting).
Remove molding under door arm rest by gently prying with a flat tool (Thin spatular)
Then remove the two bolts.
Pry the panel away from the door with spatular, remove and prop up.
This will expose the connection point of the mirror wire plugs. I then removed the mirrors two male plugs. Next I removed the 3 , (T 26 socket fitting) carriage bolts. The mirror comes free remove the wire from the door opening. Then assemble in reverse order. Excellent!!!
The unit was basically plug and play. All the features work, but most of all the small point of view on the passenger side has increased dramatically. I feel more secure now because I can see more on both sides.
PS; you will want to have some spare door plastic clips to replace damaged ones $1.50 each
That's the story!!!
Swefoto
Cure for small vantage point. The 06 side mirrors were always to small for a truck/SUV because they were originally designed for the sedans. For my 06 ML I purchased the new 2011 164 mirror assembly.
remote fold away,
lock and fold away
auto dim,
defrost heated,
That's the story!!!
Swefoto
Hello swefoto, i am trying to do the same like you. My ml has memory seats, antifrost, dimming, folding, etc.
I bought in eBay a pair of mirrors that doesnt have memory. Please tell me if the mirror must have a different motor with memory or the memory function comes from the seat module.
Here you can see the ítem in eBay: http://www.ebay.es/itm/170893120203?...#ht_1352wt_922.
Thank you very much
Quote:
I think it's for the auto-dimming feature.Originally Posted by swefoto
Agreed IMO very expensive. Esp. the driver's side mirror. It has some liquid metallic compound inside the glass elements. Don't ask me what it is duno. But perhaps when an after market mirror becomes available at a fraction of the cost then it could shave $600. of the cost
ExploreNewbie
remote fold away,
lock and fold away
auto dim,
defrost heated,
That's the story!!!
Swefoto
I know it has been a while since this thread has been used but I am interested in doing the swap for my 2007 ML320. Does anyone know where I could find the 2011 side mirrors. My vehicle is alabaster white. Thanks for any help in advance. I have searched near and far for these side mirrors..Originally Posted by swefoto
remote fold away,
lock and fold away
auto dim,
defrost heated,
That's the story!!!
Swefoto
Quote:
they are mercedes in Medford, Oregon
The most costly item is the driver's mirror glass. $592.
psgr side mirror glass $122.
mirror motor$333.
cover $87.
cover molding $55.
what a waste of money to buy from official dealer ,I'm always buying Taiwan made for complete unit 200 usd from my sources in China fits like original ones except they have no blind spot triangle markOriginally Posted by swefoto
Not cheap!! About $1700. from www.mbzwholesaleparts.comthey are mercedes in Medford, Oregon
mirror motor$333.
cover $87.
cover molding $55.
Leon thanks for the response. Do you have a link to where I could purchase the ones you get? Do they come painted?
Thanks..
Thanks..
[QUOTE=appstategrier;6823300]Leon thanks for the response. Do you have a link to where I could purchase the ones you get? Do they come painted?
they come unpainted except black as I know ,you can use these for contacting them ,they are keen to serve and knew English well
Mobile Phone:+8618122399971
Viber:+8618122399971
Wechat:18122399971
Whatsapp:+8618122399971
Wechat:18122399971
you are welcome ..I have plenty of sources for parts over there ..any one who wants to run good business for parts low rate I'm here to give good advise
Anyone has instructions to replace the light bulb for the courtesy light in the under side of the mirror.
I am thinking of switching it to a brighter LED
