jack stands
Old Dec 9, 2011 | 07:36 PM
patrick30's Avatar
ML350
jack stands
I searched & searched. Where have folks placed the jackstands on (06) ML350. When I remove the lower engine cover- can I place it under that brace? By the time I place floor jack in the correct sill jacking point- no room for stands.
Old Dec 12, 2011 | 09:29 PM
Moto One's Avatar
w164 (ml 500)
I placed my jack stands at the pick-up points at the rear of the front suspension for the front.
That was all.
Old Dec 14, 2011 | 06:10 PM
rickybooby's Avatar
ML
Mine broke when jacking up the car, jacked just popped out(the pole grinding on the gears)
Old Dec 15, 2011 | 09:17 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Don't use that cross brace. I put the jack stands under the inboard side of the control arms, near where the arms and the frame bolt together. You will see what I mean when you are under there. Just use care to make sure the ramp is stable with the weight as your jack stand top may be different from mine.
Old Dec 19, 2011 | 04:49 PM
lkchris's Avatar
'10 CL550, '12 GL550
Vehicle is not designed to accomodate jack stands.
