Light output on projectors
So I installed a aftermarket HID kit and it improved, and still the passenger side is fully outputting light and the driver, barely anything. I tried leveling it again and no matter how high or low or middle I leveled it, the light output was not shot out at full force. I drove to a dark place and level ground and parked infront of a flat wall from a good distance to see the cut-off line and to make adjustments.
As I level the driver side up and down, I can only see like shadows of the light, my right side of the wall was white and the left side was still dark and I move the projectors up and down, the light output was probably 35%.
Anyone have any idea how to fix or know what the issue is?
PS. and the driver side light output on the ground is weird, theres a line of light at all and passenger side is normal. Heres a pic. In real life the driver side is not bright AT all, the picture from my phone just made it seem that way on camera.
Uploaded with ImageShack.us
Update: I quadtroble checked and everything is properly set in place, put in brand new bulbs and still the same result of 1 side brighter than the other. =/
What is the projector bowl and how do I try to fix it?
If you walk by and look at both headlight, they look exactly the same, same color, same light output, but when you look at the wall, or drive it at night, you CLEARLY see only the passenger side is fully lit up.
