2007 Navigation
Old Jan 1, 2012 | 08:21 AM
maximus350's Avatar
07 ML350
2007 Navigation
Purchased a used 07 350. Does not have navigation, but the head unit has all of the buttons that say NAV and so on. Can I simply install somthing to get navigation or do I have to install a new HU.
Old Jan 1, 2012 | 05:04 PM
GateKeeper's Avatar
GLA45 AMG, GLC43 AMG
if your vehicle is like mine, then the slot for the DVD is behind the head unit, same place you would put in a CD, pressd the eject button and once the heaad unit opens up, if you see two slots, you should be able to use NAV Dvd, one will be for the NAV and one slot for regular CD's, should be clearly marked
Old Jan 1, 2012 | 05:16 PM
maximus350's Avatar
07 ML350
Thank you, I will check that. I did push the eject button and the HU opened up but dont remember how many slots I saw. I know there was one. I will check. Also there is an option on the HU for cd and cd magizine. Where would the cd magizine be located.
Old Jan 1, 2012 | 05:52 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Originally Posted by maximus350
...Where would the cd magizine be located.
Upper side of inside glove box. Silver button drops it down. Also you may see an axillary headphone input jack.
Old Jan 6, 2012 | 07:29 AM
swefoto's Avatar
ML 350
Navi unit
If you don't have the Navi DVD drive the hole unit can be bought from www.mbzwholesaleparts.com or call they are in Medford Or. 866 353 2369 and ask for Jeff The price is about $1300 can be programed to run on your command scren with maps and all.
Good Luck!!
SWEFoto
