Where is the battery
Old Apr 8, 2012 | 06:55 PM
ml350man's Avatar
2009 Ml350
I have a 2009 ml350 just wondering where is the battery
Old Apr 8, 2012 | 09:06 PM
Moto One's Avatar
w164 (ml 500)
Check under the passenger seat!
Really!!!
Move it full up and forward to access.
Mark
Old Apr 9, 2012 | 05:58 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Also get your razor blade out and cut the carpet.
Really.
The cut outs are provided in the carpet area.
Old Apr 9, 2012 | 08:20 PM
MAmendola's Avatar
2014 ML350 Bluetec, 2016 GLC 300, 2023 Corvette, Z51 Stingray
Not sure if you need to cut the carpet or not. I moved the passenger seat all the way forward and removed the plastic cover where the rear heat ducts are. I then remove the black plastic cover above the battery. I checked and the battery will lift out once the pos and neg terminals are removed. There are cutouts as mentioned if you do need to cut the carpet
