Not sure about headlights...
Old Apr 9, 2012 | 01:21 AM
SirML350's Avatar
2009 ML 350 4Matic
Hi all, this is my first post on here and I wanted to know how do I determine if I have Bi-Xenon headlights or not?! I've heard that my headlights will be a bright whitish/blue if they are, but mine are slightly yellowish.
Old Apr 9, 2012 | 08:40 PM
MAmendola's Avatar
2014 ML350 Bluetec, 2016 GLC 300, 2023 Corvette, Z51 Stingray
Yes they should be a whitish blue. Also pop the hood an you should see yellow stickers on top of the plastic housing near the lights that have a yellow lightning bolt and 25000V printed on the sticker
Old Apr 9, 2012 | 10:36 PM
SirML350's Avatar
2009 ML 350 4Matic
The lightening bolt/sticker indicates Bi-Xenon equipped is what you mean? Thank you for your help!
Old Apr 10, 2012 | 12:14 AM
wongster's Avatar
09 ml350 4matic
usually if you have headlight washers and led tail lights, you should have factory bi-xenons.
Old Apr 10, 2012 | 12:31 AM
SirML350's Avatar
2009 ML 350 4Matic
Thanks a lot
Old Apr 10, 2012 | 07:46 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
All Mercedes in the US that have factory Bi Xenon's "lighting package" also have headlamp washers. Fastest way to tell just look at the front bumpers, under the headlamps and you will see the door flaps for the washer nozzles.
