2009 ML350
Bought used cpo this month..
Dealer said trans and filter should be replaced at 39k miles
Also since they are in there...the gearbox oil too..$600..
They found a leak in the rack and replaced box and rack..covered by warranty.
2 hour service took all day
...they gave me a car though..I'm thinking another 2yr cpo for $3200 may not be a bad idea???
What say you???
It was 2000 for the first year or 3200 for 2 years.I guess cheaper than a trans. My rack and box was just replaced for leaking at 45k miles. Never saw a spot on the floor..
Look for leak in front rack.
Was transmission serviced properly..40k trans fluid filter change...or you might be doa..
Brakes cost 600..so check life
Otherwise...don't worry be happy!!!!!
520 for pads rotors and sensor rear only
recall item 48476
install cam solenoid harnesses
027325 electrical wiring harness for solenoid of camshaft adjustment retrofit
code 5683 wm8
covered by cpo any body know what they did
MERRY CHRISTMAS
Good luck and Happy New Year
Mark
Never had them before but see that they are available at discount tires for 19inch wheels.
If not what all weather tire do you suggest?????
Or are they just a waste of money?
