2006 ML-500 Coin Tray
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
I really do not consider that a coin tray. I had that in my 06 and have it in my 10. Believe the OP is looking for something that goes in the center consol. There really is no way to retrofit the small drawer economically as the entire center dash must be redone.
In any case, you don't need to remove the dash. You just have to pull out the fascia. Pull the ashtray first, remove 2 side-screws to take the ashtray compartment out. Then push the fascia UP and pull out. The coin tray has its own 2 side screws. It is a closed box, not like the ashtray.
See:
http://ww2.justanswer.com/uploads/eu..._coin_tray.pdf
http://www.justanswer.com/mercedes/4...tay-close.html
I just can't find a replacement part.
Im also trying to find coin tray replacement for w164 2009 ml350 can't find anywhere. I was able to pull the old one out. Thx in advance
Do you have a cigarette lighter?
Look for a part number on the tray, #164 xxx xx xx, and post it.
Also take a photo of where this tray is located.
