2010 ML350 AWD Towing
Old Jul 26, 2013 | 09:55 PM
MiamiZ's Avatar
Ml350
I had a brand new Nissan Titan (RWD) on a boat ramp a few months back. Put the truck in park and the emergency brake on. When I went to get my boat the car slid into the water. There was no load on the truck...just parked on slime. The lesson? Trucks are RWD and so are emergency brakes. If your rear wheels slip it's all over!
So AWD was a big factor in purchasing my ML350. So here's the question: If you put an AWD vehicle in park (turned off) do all the wheels lock?
Old Jul 26, 2013 | 11:04 PM
N4HHE's Avatar
2009 ML320 Bluetec
It would be nice if it did but I don't expect so. 4MOTION is implemented with free differentials not locking/limited slip. The limited slip function is performed by independently braking the spinning wheel.
Old Jul 27, 2013 | 04:50 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Driver should stay in truck and apply brakes while offload boat. Your buddy or wife can offload boat. Gl
Old Nov 30, 2014 | 11:06 PM
N4HHE's Avatar
2009 ML320 Bluetec
Update: While installing brake pads today with ML in park but parking brake not set, none of the wheels would turn when one at a time was off the ground.
Old Dec 1, 2014 | 03:07 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Park keeps the transmission from turning, and therefor for one axle to turn the other has to turn in the opposite direction.
With the parking brake set the back wheels (and hence the back axle) will not turn therefor the front axle will not turn. (if one wheel turns the other has to turn the other way.
In general with the transmission in park and the parking break on three wheels need to loose almost all traction to slide/
