CHECK ENGINE LIGHT-P20BD?
Old Feb 7, 2014 | 08:47 PM
djjoonie's Avatar
AMG GTs
Hello all, I have a 2010 ML350 Bluetec and I just got a CEL-p20bd (Reductant Heater"b" control circuit open")... I was in Vermont this morning and the temperature was 1F and I got the cel as soon as i started the car. what do you think this is?
I just did a reset with the little scanner since driving back home to NY the code didn't get erased. so I deleted the code after driving for 5 hours. I just hope it doesn't come back on.
Old Feb 7, 2014 | 09:30 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
I found this
P20BD rotate angle error between left cylinder bank camshaft and crankshaft (P0378)
Your code seems to be for a Ford.
Old Feb 8, 2014 | 12:09 AM
djjoonie's Avatar
AMG GTs
Originally Posted by N_Jay
I found this
That sounds complicated and headache. Just hoping the light doesn't show up again but since I have the cpo warrenty i hope everything breaks b4 the warrenty expires
Old Feb 8, 2014 | 12:16 AM
N_Jay's Avatar
Sounds like typical cam magnet problem (Just a wild guess)
Don't clear codes if you have a CPO warranty, get everything you can fixed.
Old Apr 18, 2015 | 11:24 AM
STLML350's Avatar
ML350 Blutec
Did you ever figure this out? My 2010 just popped this code
Old Apr 18, 2015 | 11:25 AM
STLML350's Avatar
ML350 Blutec
I just got the same code, did you ever figure this out?
Old Sep 7, 2015 | 10:49 AM
billviv's Avatar
2010 GL350
Just got this code to for my 2010 GL350; Of course, my cpo warranty expired two months ago.
Old Sep 8, 2015 | 12:29 AM
STLML350's Avatar
ML350 Blutec
If you have a Blutec its the Addblue tankheater gone bad. Could be faulty wire lose connection or in most cases replacing.
Old Feb 13, 2016 | 05:46 PM
mothi's Avatar
ml350
I just got a CEL-p20bd (Reductant Heater"b" control circuit open").any suggestions
Old Feb 14, 2016 | 06:04 PM
STLML350's Avatar
ML350 Blutec
More than likely a bad heater, only fix is to replace
Old Feb 18, 2016 | 11:08 AM
loungeliz's Avatar
2010 ML350 bluetec
I have similar problems as well. My check engine light is throwing 3 codes:
P2069: Reduction heater 'A' control circuit open
P2005: Intake manifold runner ctrl stuck open bank 2
P2413: Exhaust gas recirculation sys perf
I reset the codes, they come back right away. So booked a service appointment next week. Will let you guys know the outcome, but my psychic powers tell me this is a 4 digit fix $,$$$.
