Gear indicator displays D1 to D7 instead of just D? what's the problem?
Old Mar 16, 2014 | 08:01 PM
s900s900's Avatar
ML350
Cool Gear indicator displays D1 to D7 instead of just D? what's the problem?
I am driving a 2014 model ML350, at the very first day i remember the indicator shows only D, now it shows D1 to D7 dynamic when the speed changes.
When i using the paddle shifter it shows 1 2 3 etc, with M.
anyone knows what D1 D2 D3.. etc means? is it still on auto shifting?
Old Mar 16, 2014 | 08:30 PM
Phil.mount's Avatar
2006 ML 350 sold, 2014 Bluetec "Rudy"
My '14 BT shows the gear it is in, at lower speeds it holds certain gears which I assume matches the torque to speed. I really like it. As speed increases of course the gears go up. The selector has been put in D but it shows the actual gear. Hope this helps.
Old Mar 16, 2014 | 09:24 PM
s900s900's Avatar
ML350
thanks, it helps a lot.
is it kind of like a new feature for 2014 model ? real time gear indicator or something, i found some relative post on SLK forum. http://www.slkworld.com/slk-r172-gen...indicator.html
Old Oct 24, 2021 | 06:49 PM
Issac2021's Avatar
ML350
I met the similar situation and it horried me. I worried about whether the transmission has some problem. Thanks for your post.
Old Oct 25, 2021 | 03:16 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
You are on the wrong forum.
https://mbworld.org/forums/m-class-w166-149/
