Weird blinker problem....
Old Jul 21, 2014 | 11:26 PM
Dkennel's Avatar
2009 ML350
I have a problem with the front right turn signal. The large amber light below the headlights stays on constant, even with the ignition off and key removed. I tried to swap left and right side bulbs, but same problem. Only solution to keep the battery from draining was to remove the bulb on the right side.... Now of course I get the error message right turn signal bulb defective. Any ideas?
Old Jul 22, 2014 | 12:25 AM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
I would guess the SAM.
Old Jul 22, 2014 | 12:51 AM
Dkennel's Avatar
2009 ML350
I think you are absolutely right. My stepdaughter had spilled laundry detergent under the seat.... So looks like water/liquid damage to the SAM. I pulled out the battery and cleaned out the compartment as best as I could. I suspect the SAM is the rather large box towards the right of the battery? How do you remove it? Does the seat need to come out? It looks like it goes under the seat rails. Is there any chance of cleaning out and drying the SAM or is all lost? What cost am I looking at?
