2008-ML350:P0019-Crankshaft Position-Camshaft Position Correlation (Bank 2 Sensor B)
I will try to change the camshaft valve first to see if the light goes off. My car drives very well and I replaced the parts you indicated before but the light goes ON again.
In youtube there is a video about it. Many ML350 have had that problem here in USA. Lucky you that the problem was the camshaft exhausted control valve only. Julio
Hello, I’m getting these codes on a 2007 s550. I just recently changed all four cam magnets adjuster and also replaced one oxygen sensor then these three codes started showing. So far, car drives normal but check engine light stays on. Please help. I can be reached on 443-621-7483 or please, explain in details what needs to be done to fix these codes. Thank you.
Hello, please I’m getting these three codes on a 07 s550. Car drives normal but check engine light stays on. I just recently changed the four cam adjuster magnets and one oxygen sensor. Please, help. I can be reached on 443-621-7483.
