Engine oil
Old Dec 24, 2014 | 10:29 AM
Iamnotfat's Avatar
ML350
Engine oil
I have a 2011 ml350 bluetec
I recently had the oil changed and I used Mobil1 0w40.
However the oil did not state that it was for diesel engines... It's this okay or will it damage my engine?
Thanks for your help and feedback.
merry Christmas!
Old Dec 24, 2014 | 10:45 AM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
You run the risk of clogging your exhaust filter.
Old Dec 25, 2014 | 10:11 AM
SiRudBi's Avatar
Top Answer: 1
2017 AMG C 43 (W205); 2019 E 300 (W213); 2008 ML 320 CDI (W164)
I wouldn't use any oil other than oil which carries the MB specification that the particular diesel engine requires. On the 2008 pre-bluetec diesel model the required specification by MB is 229.51 or alternatively 229.52. There may have been other specifications before and the bluetec engine may have a different requirement to the pre-buetec engine. These oils are not exclusively available from the MB agents only but in the past when I've priced this oil in our area, the oil at the agents (CAD $12.18 per litre including tax) was the same price or even slightly lower than elsewhere. You could probably get the oil on the internet for less.
Old Dec 25, 2014 | 02:04 PM
Iamnotfat's Avatar
ML350
Thanks for the help and feedback so far guys.
Yeah the specification said to use 229.51.
The Mobil 1 I used said it's the recommended brand for Mercedes and other European cars. It's synthetic and it said (229.5) on the back. On the front it didn't have that (for gasoline engines label) that other oils normally have... Hence I thought it could have been used for both.
Old Dec 25, 2014 | 08:14 PM
SiRudBi's Avatar
Top Answer: 1
The MB 229.51 specification oil is designed for recent Mercedes cars fitted with EURO IV and EURO V engines and applies to some Mercedes petrol engines and some Mercedes diesel engines.
Mobil 1 certainly produces an oil which meets the 229.51 specification but I think there are other brands now that also produce oil that meets this specification.
Old Dec 25, 2014 | 11:14 PM
N4HHE's Avatar
2009 ML320 Bluetec
Yes, you have the wrong oil in your engine and you must remedy the problem immediately. Its worse than just not dotting M-B i's and crossing t's, there are huge differences between gasoline-only motor oil and those rated for use in diesels. Most all diesel oil is rated for use in gasoline engines too, but not vice versa.
Perhaps you noticed how ink-black the drained oil was? That is normal for diesels, but not normal for gasoline engines.
"Synthetic" is utterly meaningless when it comes to motor oils. Synthetic is not a performance criteria or standard, it is a manufacturing technique. If used right a superior product could result but just because the techniques were used is no assurance of a superior product.
Drilling down deeper 229.51 is a low ash oil, about half the ash of the best commodity diesel motor oil you'll find at Walmart. Ash is bad for DPF and SCR components in your exhaust.
