Rear air suspension sag. ML 320.
Old Mar 10, 2015 | 11:09 PM
Mercdz ML's Avatar
ML320
We have a 2007 ML320 with a problem that I would appreciate some advice with.
The air suspension on one (rear) wheel has a tendency to 'sag' approx 2" if the vehicle is parked for 2 hours or more. It immediately re-establishes height and correct suspension once the door is unlocked or opened. It also emits a single 'hissing' noise over the affected wheel at the same time. It is then fine for driving and doesn't show again until it has been parked for a couple of hours or more. I have been advised that I may need the shock absorber and airspring assembly replaced.
Has anyone else any similar history with their car and are their any other known possible causes such as a leaking valve etc?
Thank you,
Peter.
Old Mar 14, 2015 | 02:54 AM
averskog's Avatar
ML320 CDI 2007, 300E 24V Cab 1993
Airspring leak
Hi, you have a leak in the airspring, my advice is not to wait to long to change it, otherwise you may burn out the compressor. No need to change the shock absorber.
/Mike
Old Apr 25, 2015 | 10:00 PM
Mercdz ML's Avatar
ML320
Sagging rear suspension
/Mike
Thanks mike, I have had both airbags and shock absorbers changed. Problem fixed. Not cheap though.
Old Apr 28, 2015 | 01:13 PM
N_Jay's Avatar
2019 WS222 S450 4-Matic / 2007 W211 E350 4Matic (Sold) / 2008 X164 GL320 CDI
Why did they change the shocks (other than to extract extra mney from you)?
Old Apr 29, 2015 | 04:59 AM
texasflysuper's Avatar
ML350
They would have said the old
"while we have X out we might as well change X too, you know - just in case"
That line never gets old.
Old Apr 29, 2015 | 08:34 AM
N_Jay's Avatar
LOL, the airbags are 30 minuets under the car, the shocks are about 2 hours inside taking the interior apart.
If they were not leaking they were not bad.
Old May 16, 2015 | 01:02 AM
Euler's Avatar
2008 C63, 2008 ML550, 2014 KTM 500 XC W, John Deere 990
Rear air springs are an easy DIY. You have to be careful with the air line though.
