ML500 Airmatic Compressor Stalls Engine
The problem now is that soon as the airmatic compressor kicks in the engine stalls. If I restart I can only get a few hundred metres before it stalls again.
Even when stationary the engine stalls as soon as I use the raise vehicle function and the compressor kicks in.
Has anyone else experienced this problem?
I am assuming I am up for a new compressor and hopefully nothing more sinister but am extremely surprised that a compressor fault can result in an engine stall. Vehicle is a 2006 ML500.
The relay which was sticking on blew out a track of the circuit board under the fuse box. This resulted in a circuit error which caused the ECU to shut down the engine every time the airmatic compressor kicked in. It appears that the compressor has survived.
Breathe a sigh of relief. The compressor ain't cheap.
