Rear SAM. Where is it located and what does it look like?
Old May 9, 2015 | 10:59 AM
Mercdz ML's Avatar
ML320
Question: 2007 ML320 CDI - can somebody tell me where the rear SAM is located and what does it look like?
I am having problems with the power tailgate and I want to have a look at the terminals on the SAM
Thank you,
Peter.
Old May 11, 2015 | 07:03 AM
Mercdz ML's Avatar
ML320
Thank you,
Peter.
Old May 12, 2015 | 11:29 AM
framer's Avatar
2007 ml350
Remove passenger side carpet side cover. See the fuses? The sam is directly below that. Kinda hard to see. There is a black plastic cover over it that can be easily moved. Then lift the sam and maneuver up and out.
Old May 13, 2015 | 09:08 AM
Mercdz ML's Avatar
ML320
Left or right hand drive?
Thank you Framer,
When you say "passenger side', do you mean the Right front passenger seat on a Left hand Drive or the Left front passenger seat on a Right hand drive? Is it the same box where the battery is? My car is Right hand drive and the battery and some fuses are under the driver's seat. Thanks again,
Peter.
Old May 13, 2015 | 11:51 PM
framer's Avatar
2007 ml350
in your case, it would be the drivers side. in the cargo area, behind the tail light.
