How to remove parking brake pedal cover?
Old Jun 16, 2015 | 09:57 AM
OUZO Power's Avatar
JGC SRT, ML 550, GLB 250
So I got these slip on pedals. The gas pedal and brake pedal went on easy and they look really good.
But the 3rd which is the parking brake wont slip on. The pedal cover has to be removed but I've tried and there is no way I can get it off.
Does anyone know how I can get the rubber/plastic piece off?
Thanks.
Old Jun 17, 2015 | 12:43 AM
beerj's Avatar
2006 Mercedes ML 350
If it is the original brake pedal pad it should peel off with no problem.
Since it does not come off the way it should, it might be either an aftermarket part that is attached in a different way and/or glued on by the previous owner .
Brute force might be the answer here.
Old Jun 17, 2015 | 09:33 AM
OUZO Power's Avatar
Thanks for the input beerj.
But I don't think it's aftermarket. See pic.
Old Jun 17, 2015 | 11:32 AM
OUZO Power's Avatar
found it. Shown at 1:30 mins.
Old Jun 17, 2015 | 04:09 PM
beerj's Avatar
Is this what you are installing our what you are taking off to replace it with the metal OEM Mercedes pedal covers ?
Old Jun 17, 2015 | 04:30 PM
OUZO Power's Avatar
I want to get that off to install slip on metal pedals.
Still no dice. It won't come off.
I think I'll have to slice it off with a knife
Old Jul 3, 2015 | 11:50 PM
beerj's Avatar
How did the parking brake pedal get fixed eventually ?
Old Jul 6, 2015 | 10:01 AM
OUZO Power's Avatar
never got around to it. But it's on the list.
