Liftgate Problems on ML350 - Pump or Struts?
seems like the struts on my 08 were not that expensive and maybe it would be worth starting there
sorry not much help, maybe someone with more experience with that will chime in
i also think the rubber was sticking sometimes and not letting it up
the handle part number on mine has been superceded a time or 2
so i went ahead, did the handle and the struts/shocks not knowing what the problem really was , just figured the shocks were getting old
and at some point i read weak shocks will eventually wear out the motor
after putting these new parts in the mechanic spent maybe 20 minutes getting it all adjusted correctly
i also make sure to put armour all or something on the rubber every month or so to make sure it does not stick
since doing all this mine has not messed up once in months, works perfect every time now
hated it before and now i love it
but i thought the newer ml's had most of the kinks worked out of the power liftgates...
my issues sound different than yours
lol, pretty much any part for my cars that is around 100 or under is cheap to me, sorry to be misleading
