Steering wheel trim peeling- replace?
Besides looks, it is kind of sharp where it is peeling.
I did some looking and cannot find anything detailing those trim pieces at all.
Any way to replace without buying a new wheel?
It looks like the plastic pieces would come off, but I can't find anything that mentions that.
Thanks!!!
That is the black version- not sure what other color part numbers are.
That part number shows up off a 2007 /8 GL320 steering wheel diagram. With that info you should be able to find other colors if needed.
To get them off, use a plastic trim tool and pry at the tip nearest the wheel. Just go slow and they will pop right off.
Curious - where did you see them online? I did a quick Google search and found some random sites, but nothing that really screamed "legitimate retailer," you know?
// edit - I guess this is the site you're talking about? http://www.mbpartscenter.com/oe-merc...16446006959e37
When you remove the lower trim you'll see torx bolts that need to be undone to get the card off.
On the front doors you need to access another torx under the door-lock buttons. Between the buttons is a plastic divider which can be pulled up a bit with your hands/flat head (from the door handle side). Then get a decent grip on it and pull out to remove the buttons.
On the rear doors there's a torx under the tweeter grill. You can use your fingers to "slide" the grill towards the back of the car and it'll pop off.
After undoing all torx bolts you can use a trim pry tool around the perimeter of the card to undo a series of clips. Start at the bottom. The top of the door card will need to "slide up" after you've undone all torx and bolts. Take care to not rip any cables attached to the door card's speakers & buttons.
just a quick question about removing these trim parts on the steering wheel...
Kerunt you said they come off easily, do I need to remove the air bag part of the wheel or can I just prize them off with the airbag in place?
Cheers
Stephen
I really fancy doing the door trims too but not sure I want to remove the door card.
Also, this is probably a common issue too...the leather material on the centre arm rest has all cracked and could do with being replaced/ repaired, what are the options?
Here's what they look like form the back side (these have been painted black). Those long tabs on each one, cause a little bit of extra resistance getting them on and off, but I haven't had any issue with breaking them.
