Airmatic Issue
Old Mar 1, 2016 | 04:09 AM
ml_gibbon's Avatar
ml320
Airmatic Issue
Hello
I've got a ml 320 2006 with the dreaded Airmatic warning light that comes on after 20 minutes of driving. The front drivers loses a cm in height overnight (12 hours), and there is a knocking on the same side when going over bumps.
Could this mean new struts/springs?
Diagnostics (Carly) has the "reservoir is taking too long to fill up error"
Thanks for looking!
Old Mar 1, 2016 | 03:23 PM
ml_gibbon's Avatar
ml320
Originally Posted by Plutoe
I don't know what Carly is but your diagnostics are short on teeth---you need to find someone who has a copy of DAS to get you out of this problem or you will be run around the parts may pole without a solution!!
Definitely agree... I'm getting it checked next week.
This is the output from carly.
AIRmatic (MB: 2515451832) Fault: Recovery time during filling of central reservoir is too long. Code: 005503 ESP - Electronic stability program (MB: 2515450832) Event: CAN signal 'Ratio' from control unit N15/3 (ETC [EGS] control unit) is implausible. / Fault: DTR : CAN signal 'Ratio' from control unit Transmission control module is implausible. / Fault: DTR : CAN communication with transmission control unit is faulty. DTR : The CAN message from control module N80 (Steering column module) is invalid or implausible. ( Cruise control lever ) Code: 007223 Event: CAN signal 'Target/actual gear' from control unit N15/3 (ETC [EGS] control unit) is implausible. / Fault: DTR : CAN signal 'Target/actual gear' from control unit Transmission control module is implausible. / Fault: DTR : CAN communication with transmission control unit is faulty. DTR : The CAN message from control module N80 (Steering column module) is invalid or implausible. Code: 007222 Event: One or more signals sent from control unit N51 (AIRmatic with ADS control module) via the CAN bus is implausible. Code: 005539 Event: The supply voltage of the control unit is too low (undervoltage). / Fault: SIC - Long term compensation disabled. (FP: 20 FT: 01) Code: 006001 HAQ - Interwheel differential lock at rear axle (-) ECU not present/no response from ECU
The carly is a mobile app... Output is below.
