EGR Temp sensor B16/14 ??
Old May 2, 2016 | 01:28 PM
gaineserau's Avatar
2009 ML320 Bluetec
Hey all,
2009 ML320 Bluetec
Thanks for info in advance but I have an intermittent code--10EF00 "Component B16/14 exhaust gas recirculation temperature sensor, has a plausibility error"
Mostly this happens during the first drive of the day. Does anyone know exactly where this sensor is? I'd like to check it and then order a new one if need be. Anyone have a part number? I have been looking all over the internet...Many thanks.
Old May 7, 2016 | 03:00 PM
gaineserau's Avatar
2009 ML320 Bluetec
Originally Posted by Plutoe
Remove the engine trim cover and look behind left side of fan---the sensor is mounted on a pipe that makes a turn---the torque requirements is 45Nm----I believe the part is VIN sensitive therefore get the part number at a dealer!!
I'm pretty sure I know exactly what you're talking about . Thanks so much for the help!
