disel owners check your injector seals
thought i posted about it here but maybe not
this is a pretty easy and cheap fix IF caught early
gets to be a bigger job and more pia if caught later
pull the black foam rubber around the injectors and toss it
once they start leaking this makes it worse because it melts on there
and with it out you can check often
there is a lot of info under black death for the 2005-06 e class diesels
and for some stupid reason mercedes used the same set up on our V6 motors...
hope this helps someone else
Just wondering what it is that causes the foam rubber to 'melt'. Is it from contact with diesel fuel leaking from the injectors or is it the heat from escaping combustion gases when the injector seat to the cylinder head is leaking?
