2006 ML500 - Front jack point location
Either this truck doesn't have one in the center like most Mercedes or I'm missing it. I know the side take-up spots, but I would rather use those for jack stands.
Not my car and I don't usually get under it so I'm leaning more toward I'm missing it. Any help would be greatly appreciated.
Did you ever figure this out? Planning to do a transmission service and need to put the car on jack stands. My ML is missing a couple of the rubber jacking points, can I just use the metal above them?
Is there a single point lifting location at the rear of ML500 using a floor jack. And once raised where would you place the stands with U pads. The stands I have cannot be used on the inbuilt jacking points of the car.
Thanks,
Thanks,
