2008 ML350 misfiring cyl 6 under load
I have seafoamed the oil and fuel tank (1 quart in the tank, half a quart in the oil, then ran it for 5 miles. I will let it sit overnight and drain the oil and see if there is any difference. I am now thinking more and more that I have a burnt exhaust valve.
I will do a manual compression and cylinder leakdown test tomorrow.
You have to determine if the Brake Cleaner traveled down to where the intake mates with the head. Seal off the mating area and re-spray.
When you swapped the injectors, did you use new O-rings?
To confirm, no brake fluid has been near the injectors, brake cleaner only.
What is you model designation, 164.xxx?
I initially decided to replace the cylinder head, due to 2 different mechanics diagnosing (guessing) it was bad.
After receiving the ebay unit and taking it for refurb, the cylinder head company told me that it was not able to be rebuilt, so while I decided whether to order a brand new one, I decided to put another $75 of Seafoam through the injectors, inlet and crankcase. I also replaced the o rings on the injectors of that bank just to be safe. I drove the car with the Seafoam for 100 miles, and each trip it got better and better, allowing me to drive for further and harder before a CEL came on. It was pumping out some white smoke, but that cleared up. Then I drove another 100 miles with no CEL at all and I replaced the oil again. The 200 miles old oil came out very black with black specs in it.
One morning a few weeks later, I got another CEL and pulled a code for the crank sensor. I replaced the crank sensor and did a learn-in procedure and it has run perfectly ever since. No check engine lights, smooth, lots of power. I think the root cause of the issue was carbon build up on the valves was preventing proper seating of the valve.
