ML 3 bluetec fault code P20E821
Old Apr 30, 2017 | 05:50 PM
David Hunt's Avatar
2011 ML 350 bluetec
Generic code P20E8 refers to low pressure in the bluetec tank. MB code adds a 21 number to this code. Does this designate a subset to the low pressure such as a bad pump, fault wire connection, fuse, etc. .
Old Jan 7, 2019 | 01:44 AM
komi999's Avatar
GL350
P20E821 / P20E823 each code happened once in last week. My ICarsoft EU Pro (Gen 2, MBv01.35) tells as much as my $25 scanner does -- which is AdBlue Pressure Low, thats it. No further information whether pump or connection is bad.
AdBlue Tank capacity is 31 Liters (full tank). When error code generated, I have 21 liters in tank. So Adblue is not empty.
still looking for cause of error code
P20E821 / P20E823
Old Jan 7, 2019 | 02:17 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
If you are asking about a GL350, you are on the wrong forum.
https://mbworld.org/forums/gl-class-x166-173/
